6890 power board removal
Posted: Wed May 05, 2010 4:53 pm
by EnvironLab
Does anyone know how to detach the power button from the AC power board for a 6890 GC? Looks like there might be some trick to it or maybe a special tool required.
Posted: Thu May 06, 2010 3:00 pm
by aldehyde
Pull
. I can't remember if it hooks in from the left or right, you might have to give it a slight push, but it just comes off.
Posted: Thu May 06, 2010 3:52 pm
by EnvironLab
Thanks! Turns out I didn't need to remove it after all. But I'll remember that for next time.
Posted: Thu May 06, 2010 4:58 pm
by aldehyde
Yeah those things are really annoying, the whole push bar idea is incredibly stupid on a GC. It takes 2 people to get that sucker out if you have to replace it.
Posted: Thu May 06, 2010 6:38 pm
by Consumer Products Guy
On one of our 6890s the top of the "finger" on the board that the push bar attached to broke somehow, so the push bar would slip off. The solution was to just unplug if needed to turn off, then while the unit was open to replace the hot air vent actuator, we drilled a small hole in the finger, and used a bread tie to hold the end down so it couldn't slip off. Priceless !!!
Posted: Fri May 07, 2010 2:58 pm
by haiedc
Power button is one of the worst things about 6890. The GC is good all right, but some friends of my (and our lab also) complained about the button. After one or two years in use, it starts to get stuck or failed completely. Hope 7890 will avoid that.
Posted: Fri May 07, 2010 5:39 pm
by EnvironLab
Ha! Interesting stuff. I'll keep some paper clips handy.
Posted: Fri May 07, 2010 5:51 pm
by chemwipe
It takes 2 people
bread tie
paper clips
Hahahaha!
