Injection errors - how often do you get them?
Posted: Fri Apr 30, 2010 1:05 pm
by chemwipe
Anyone in here get these errors regularly?
Failed to pick up vial from position #X
Failed to pick up vial from front injector
Plunger error – Dirty syringe plunger?
Failed to put vial down at position #X
Tray malfunction
Turret error. Magnetic tab missing?
I get a lot of "Failed to pick up vial from front injector" errors.
Just wondering, because I get blamed for these errors, and as we know, unfortunately, sometimes these things just happen.
John
Posted: Fri Apr 30, 2010 2:13 pm
by skunked_once
I only get this error when I put the vial in the wrong position on the autosampler tray
Fortunately that doesn't happen too often.
This one happens much too often, usually because of a sticky syringe plunger, and often one hour after I have left work for the day:lol: There are also times when it seems to be due to crud buildup on the turret.
I rarely see the other errors.
Re: Injection errors - how often do you get them?
Posted: Fri Apr 30, 2010 5:08 pm
by Consumer Products Guy
We get similar errors about once a month, usually not explainable. Myself, I like to physically move the plunger to ensure there's no binding before I begin a sequence. And use the solvent rinse function, important.
Posted: Fri Apr 30, 2010 11:12 pm
by Don_Hilton
The failure to pick or place sound like alignment errors - which could be a tray not quite in place - or with some of the other errors noted, you are using an old autosampler with parts that are beginning to come loose or fail.
Posted: Sat May 01, 2010 12:04 am
by Ron
Errors in handling the vials could also be caused by the type of vials and seals you are using.
Posted: Tue May 04, 2010 1:51 am
by chemwipe
I always remember to make sure to check that the vial tray is seated securely, but...
^^^I'm sure it's this.
Any recommendations? (besides buy a new one? haha)
John
Posted: Tue May 04, 2010 2:06 am
by haiedc
John
Try to swap the jack at the rear of the GC (from Front to Rear position). It may help. But after that, you have to adjust the method: Injector = Rear (while still using Front Inlet).
I met this case once and it helped.
Posted: Tue May 04, 2010 2:11 am
by Don_Hilton
You can check to see how much can be done to recondition the autosampler. I worked with a fellow, years ago, who would pull apart old autosamplers and rebuild them. I do not know what problems he solved. But he did hold off the new purchases for a while.
Posted: Tue May 04, 2010 2:21 am
by chemwipe
Nice! Did it completely eliminate whatever problem you were having?
I'll try it next time I get a "failed to pick up vial" error.
Thanks!
John
Posted: Tue May 04, 2010 2:03 pm
by chemwipe
[Try to swap the jack at the rear of the GC (from Front to Rear position). It may help. But after that, you have to adjust the method: Injector = Rear (while still using Front Inlet).
I adjusted the method as you suggested, but I keep getting this:
Method PCB's REAR injector doesn't match the sequence's FRONT injector.
Enter FRONT or DUAL injector method or CUT the table entry from the sequence.
I've tried switching from FRONT to REAR in both the sequence table and the method and I keep getting the error above. Am I overlooking something?
John
Posted: Tue May 04, 2010 3:58 pm
by haiedc
John
First try to run several single runs (very short, just injection phse then stop) to see if the problem's still there. After that, if it's ok (finger crossed) , think about changing the method.
Posted: Tue May 04, 2010 4:29 pm
by chemwipe
Just when it looked like it was going to work, I got the
error several times. The turret was shaking and rattling as it was spinning around before each injection attempt.
I switched the control box and method back to their original configurations, then replaced the turret with one from a spare tower and now it seems to be fine - I'm sure it will be fine until I leave for the day, though!
Thanks for the tip!
John
Posted: Wed May 05, 2010 1:39 pm
by Ron
It may be ok, there are magnets attached to the turret for determining the home position, and if something has gone wrong with one of the magnet the turret won't home correctly, and that can lead to vial positioning errors. Replacing the turret is a good move, if the problems go away you have resolved the issue, if they continue it could be the sensor the magnet is supposed to trigger.
Posted: Wed May 05, 2010 6:40 pm
usually just press the turret all the way down if you get that turret error
Posted: Tue May 11, 2010 11:39 pm
by bhahn
If you need a repair to the ALS or modules, shoot me an e-mail at
bhahn@aoti.net
