Fault: Detector B Temp Reading (pictures included!)
Posted: Thu Apr 29, 2010 3:35 pm
I'm (still) trying to salvage an HP5890 Series II Plus:
I'm getting a fault with the detector temp and I think there's a short in the sensor:
If this is moved:
Then this happens:
How do I replace the temperature sensor? I'm sure I have to, but are the connections meant to be removed from here?
I couldn't get the connections out, and wasn't sure if they were permanent in there or what.
Still a rookie, but I'm trying!
John
If this is moved:
Then this happens:
John
