Thanks again for your help!!! I am new to MS analysis
Again, I'm hoping to respond to the following questions:
First I have to identify multiple-charged peaks of Poly L-lysine. This seems straight forward. My PI seemed to indicate that there would be not triply charged pk for 2-mer unit. I would think that there could be. And is is possible to have peaks with many more charges for Poly L-lysine?
Next, I need to identify the reason multiple fractions of Poly L-Lysine are visible in some of the mass spectra.
My PI indicated that multiple fractions of PLL are visible in some of the mass spectra. It seems to me that if there was carryover on the reverse phase C18 column, that I would see evidence of this carryover between peaks. but when i look at mass spectra between peaks, there is no evidence of various lower mw PLL fraction peaks. I would have thought that what he believes to be various fractions are just fragmentation of the separated mw fractions. (any ideas would be helpful)
And lastly he wants to know why the peaks in the chromatograms are not equally spaced
I don't know why my PI keeps asking about whether the peaks are equally spaced or not. He mentioned that when the gradient is steep enough the peaks will be equally spaced.
The first gradient did not separate the fractions of Poly L-lysien (PLL). The separation did not go well. ( I guess because the gradient was too steep??and the various mw fractions of PLL coeluted? Why then, are there 3 peaks. It does not seem that each peak contains higher sequentially higher MW fraction clusters???
I HPLC methods are described below:
Gradient method 1:
The first method run was a steep linear gradient from 10 to 60% MeOH; 80 to 30% dH20; 10% 0.1%PFPA M.P. composition over 6 mins.
The PPL fractions coeluted. The separation did not go well.
Gradient method 2:
A more gradual linear gradient method was run from 10 to 60% MeOH; 80 to 30% dH20; 10% 0.1%PFPA M.P. composition over 12 mins.
Gradient method 3:
A linear gradient method was run from 20 to 60% MeOH; 70 to 30% dH20; 10% 0.1%PFPA M.P. composition over 6 mins.
gradient 1
peak 1 (0.96 min)
peak 2 (3.97 min)
peak 3 (4.88 min)
gradient 2
gradient 3
peak1 (3.07 min)
peak 2(4.05 min)
peak 3 (4.77 min)
peak 4 (5.27 min)
peak 5 (5.62 min)
peak 6 (5.88 min)
peak 7 (6.10 min)
peak 8 (630 min)
Thank you very much for any suggestions you may be able to offer!!!!
