need some help with SEC principles
Posted: Mon Apr 26, 2010 12:58 pm
Hello all,
I use a GFC column in order to quantify a polymeric compound of MW about 3000 Da.
the column i use is a PSS suprema 5µm 30Å, and the eluent is 4% MeOH in water, with 100mM of ammonium acetate. (1ml/min)
When i inject a 100 ppm std, i see a peak at around 8 min (the polymer i guess) and an other one at 14 min, wich, i guess, has to be the sodium present in my sample.
but why, when i inject a sample of NaCl, do i see 2 peaks, one, for the sodium at 14 min, and an other at about 9 min, the chlorides??
I thought that, with a MW < 100 da, the chlorides and the sodium in the samples would have come together, at the permeation limit of the column (which has to be 14 min)?
I use a corona CAD detector. The UV detector at 220 nm shows me a peak at 8 min (the polymer) but also 2 negative peaks, at 9 and 11 min.
I'm not event sure i should use such a column, the goal is to separate the polymer from the matrix (sea water), and then, quantify this polymer..
