Slope Change
Posted: Thu Apr 22, 2010 9:30 am
Hey guys
Have a scenario here
I have a Dionex P680 LPG pump with ASI100 Auto Sampler and PDA 100 Detector
My column is a Supelco Supelcosil with 15 cm x 4.6 mm x 5 micron dimensions.Flow rate of 1 ml/min with an isocratic method of 90:8:2
MeOH: H2O : 0.3% H3PO4
I'm running a method with two analytes- Octinoxate and Avobenzone
The wavelength changes from 310 nm to 357 in 5.65 minutes and here is the problem
I used to get 1.3 Slope for Octionoxate and 0.95 for Avobenzone and my curve for both of these guys was coming out near to perfect with 4 point calibration with R square value of 0.9999.
After about 2900 injections on the same column my slopes have changed to 0.95 and 1.3 respectively.
My assay numbers are not off the chart- There are still in range- But I have paid attention to my slopes all the time since I have started this method and I see a change- Although my numbers are coming up "ok" , but I don't like the slope change.
Any ideas what could be happening here? Could it be the column?
Thank you in advance
