LCsolution help needed!
Posted: Wed Apr 21, 2010 11:56 am
Hi everyone!
Im having a diffucult time finding out how to do a proper fractionation on an HPLC using the LCsolution program.
I have a batch with 6 runs on different samples and in the method, which is the same for each batch run, i have a defined fractionation creating 6 elution samples. The problem is that the eluted fractions are loaded into the same vials. In other words, each batch run starts from the beginning, using the same 6 vials as the previous batch run. The result is me ending up with a total of 6 eluted samples instead of 6x6= 32.
I´ve tried to look in the manual to solve this, but frankly it is very poor, not even touching the subject of creating a method...
Does anyone have some experience using LCsolution, and how to do this properly?
BHJ.
BHJ.
