Help re Analyst Software
Posted: Sat Apr 17, 2010 2:19 pm
by wan
I am trying to analyse my LCMS data using Analyst, but was somehow getting a different interface or something in the same software in another computer.
I re-installed it and can now see the same interface, but am having problems regarding quantitation.
How do I set the program such that the analyte/IS peak area is shown in full numbers and not a number to the power of something? e.g. 29853226 and not 2.99e+0007.
Or is there even such settings?
Wan
Posted: Sat Apr 17, 2010 6:39 pm
by Schmitty
I have my columns set and saved as a template that I copy from project to project, so I haven't modified them in a while. You should be able to right-click on the top box or the area above the table and select "columns" or "edit columns". It's just a matter of deselecting the scientific notation check box and saving the settings.
Be aware, that there are different user profiles in Analyst, and if you are not in a specific group, you will not be able to change the columns. Since you installed this yourself, I am assuming that you gave yourself the most right possible.
Posted: Sun Apr 18, 2010 4:05 am
by wan
Thank you for your help! I've found the options to select the no. of sig. figures and uncheck the scientific notation box from what you mentioned. :)
