Butaphosphan analysis
Posted: Sat Apr 10, 2010 3:26 am
by thohry
Hi all,
I am looking for butaphosphan analysis by HPLC. It's a veterinary medicine. Any suggestion is highly appreciated.
Thanks.
On Refractive Index Detector
Posted: Mon Apr 12, 2010 5:05 am
by Chandresh K. Soni
Dear thohry
You Can try it on HPLC Using 0.1% Phosphoric Acid on Develosil Column or Symmetry Shield RP-8 with Refractive index Detector.may be it will help u. I was not Analyse it but Butaphosphan ( 1-(n-Butylamino)-1-Methylethyl-Phosphonous Acid.)
Posted: Mon Apr 12, 2010 11:37 am
by Bintang
With a log P value of -2,3 you will have serious problems getting any retention on a reversed phase column.
You should try with HILIC instead, the attached separation is of ATP, ADP and AMP but the problems with reversed phase separation should be related to the phosphonic acid group so it should behave similar to AMP.
http://www.sequant.com/files/documents/ ... nd_ATP.pdf
If you have any questions please contact us at
support@mercksequant.com
Posted: Tue Apr 13, 2010 1:29 am
by thohry
Thanks Soni and Bintang. I ưould try you suggestions
Re: Butaphosphan analysis
Posted: Mon Oct 16, 2017 1:46 am
by miyeko
Dear thohry,
Did you come to a conclusion with this question? I'm currently finding a quantitative method for butaphosphan as well.
