Correction factor for compound weighing/correction for salts
Posted: Wed Apr 07, 2010 8:07 pm
At my place of worship (oops, I mean work!) we use the following equation for calculation of assigned purity:
Assigned purity % = (HPLC %Purity/100) x [100-(Sum of Non-HPLC %Impurities)] x Salt Factor. Salt factor is for conversion to free acid or base.
This seems to work but my question has to do with COA's that have a test for the salt (e.g., chloride for HCl salts, maleate for maleic acid salts). The question is "do you subtract this value out as an impurity and not use the calculated salt factor?" If so, it seems the "chloride" or "maleate" tests are only measuring the anion and thus ignoring the proton which doesn't correct to the free base but the protonated base.
What am I missing? Thanks.
