HPLC to UPLC column scaling for Pharmacopeal Methods
Posted: Tue Apr 06, 2010 1:16 pm
we have some HPLC's and UPLC's running in our lab, but we would like to move to UPLC in the future.
When we are using USP methods for our raw materials, we may adjust our column length for 70%, column diameter for 25%, particle size for 50% and flow rate also 50%.
Suppose we have an HPLC method:
column: 250 mm x 4.6 ID, 10µm particles.
with some mathematics, you can find that an 100mm x 2.1mm 1.7µm particles will get an equal, or even better separation.
We found some references here:
http://www.usp.org/pdf/EN/USPNF/PF35(6)_Stim3.pdf
Are such adjustments (already) allowed?
Or can this be justified otherwise?
Ace
Ace
