Help! Settling in manually-packed columns! Weird!
Posted: Tue Mar 30, 2010 6:40 pm
Before reading on you might first want to look at the chromatograms in this figure:
http://chemistry1.che.georgiasouthern.e ... quartz.jpg
The data is from an experiment in which I made a succession of identical 10 microliter injections of 0.01M acetone onto a column that I (dry) packed with quartz sand. The flow rate was 0.5 mL/min. There is essentially no interaction of the acetone with the quartz; it is a conservative tracer that is completely unretained.
The changes in peak shape are presumably due to changes in the (dry-packed) column that occured over the time-scale of the experiment. Some of you here may vaguely recall having a similar discussion with me about this in the past, but this time I am seeing slightly different changes in peak shape.
Do you have any insight into what is going on in the column? I learned from previous discussions on this forum that the total void volume is a constant, but there may be, over the course of the experiment, setting in the column and the formation of a larger void space, probably at the head of the column, as the particles in the rest of the column settle and pack more efficiently.
My million-dollar question: How could the retention time of most of the tracer slowly increase, while a shorter-retention time shoulder appears? I have some thoughts, but I won't share them here yet. I would love to hear from the expert HPLC community.
BTW, it is abundantly clear that our current column packing protocol is failing us (sucks, to be blunt) and that we need to change it. I humbly admit that! I am open to suggestions on manual packing procedures. We are next going to experiment with slurry packing, first at atmospheric pressure, and then at higher pressure if problems persist.
Thank you in advance for your consideration and thoughtful/constructive/informative responses.
David
David
