In the majority of cases for ELSD detectable samples, FRAC will enable you to view your ELSD, UV and/or MS results as well as display the calculated concentration of each sample to within an accuracy of 20%. FRAC is unique in the market place in enabling results to be viewed in this way.
If you have not already done so, I urge you to take a look at FRAC. It could be one of the best decisions you make in 2010!
Please email me at Anthony.Squibb@chemtechsoftware.com or info@chemtechsoftware.com for further information.
