Split Acetone Peak
Posted: Tue Mar 23, 2010 1:28 pm
I am new to carbonyl analysis and I have a problem with Acetone splitting. I have 2 instruments; on one instrument, the peak does not split, but is broad...on the other instrument, the peak splits enough to manually split it. I'm fairly certain that the peak should not be splitting or be broad, but don't know how to fix the problem. It only shows up at very low concetrations. It may be the cartridges, however, I have never had a problem with them before.
Any ideas are welcome.
THANKS!!
THANKS!!
