Hazy Solution
Posted: Fri Mar 19, 2010 10:59 am
by syx
dear all, we have got problem with hazy sample solution. filtration and centrifugation cannot produce clear solution. i have an idea about aggregation followed by filtration, but i do not know how to obtain the particle aggregates. does anyone help me? thanks in advance.
Posted: Fri Mar 19, 2010 12:15 pm
by Vlad Orlovsky
Your hazy solution can be result of emulsion and not suspension. Try to add THF and see what happens.
Posted: Fri Mar 19, 2010 4:53 pm
by HW Mueller
Ultrafiltration? But please be aware that you may have a severe complication here, regarding analysis of any (partially??) dissolved substances.
Posted: Fri Mar 19, 2010 7:58 pm
by Consumer Products Guy
What have you tried for filtration? What is the solvent of your solution?
Posted: Fri Mar 19, 2010 11:23 pm
by Don_Hilton
Cah you tell us what it is you are disolving? This may help come up with an answer.
Posted: Thu Mar 25, 2010 9:50 am
by syx
we want to determine B12 in multivitamin tablets. due to its small quantity we use small volume of solvent (pH 4-5 aqueous buffer) to obtain B12 in its working concentration that be able to quantity using LC. we found hazzy solution that could not be cleaned by centrifugation or filtration.
Posted: Thu Mar 25, 2010 11:49 am
by Don_Hilton
Look at the ingreedients list for items that are not soluable in water. That may give you some ideas. This would include both organic and inorganic compunds.
Posted: Thu Mar 25, 2010 11:53 am
by danko
Hi Syx,
If the multivitamin tablets contain some or all of the following vitamins A, D, E and K, which are fat- soluble the resultant “solutionâ€
Posted: Mon Mar 29, 2010 12:41 am
by syx
it does not contain lipid-soluble vitamins. the active ingredients are water soluble vitamins and minerals.
Posted: Mon Mar 29, 2010 12:49 am
by Don_Hilton
What are the inactive ingreedients?
Posted: Tue Mar 30, 2010 9:16 am
by syx
excipients that commonly be used in capsule formulations. some active ingredients are coated separately with unknown polymer(s) to avoid interaction with other substances in the formulation.
Posted: Wed Mar 31, 2010 11:30 am
by Don_Hilton
Well, the polymers are a good candidate for being the problem. Perhaps a solvent change will either make the polymer dissolve or agrregate?
