Cleaning HIC Column
Posted: Thu Mar 18, 2010 8:06 pm
Im working with a column that has 'in house' synthesized packing, the base material is porasil silica from waters and these particles were functionalized with mixture of short oligo ethylene glycol silane and octyltrichlorosilane. I ran the column with 50 mM phosphate buffer and various concentration of Na2SO4 or (NH4)2SO4. The test sample is lysozyme, dissolve in pure water. The first set of run is fine, i get good tR and peak shape. I noticed a decrease in recovery especially at high salt concentration (max 1 M). After several hr of runs, I left it alone, the next day I failed to run the column. The recovery was extremely low, peak was very flat, tR shifted a lot. I think I have some protein left over in the column. I tried to clean the column using various solutions such as 6 M guanidine HCl, 0.1% TFA/isopropanol, 30-70% ethanol, 0.1% TFA/acetonitrile. All failed, can anyone suggest me a cleaning method? Thanks.
