I need a PTFE seal that contacts the piston and the check valve.
The 1050 manual suggests that the MCGV is a "replacement only" part, with the least expensive replacement I could find is ~$760. I'd much rather just replace this seal and have the instrument up and running.
So, if you have a broken MCGV that you wouldn't mind parting with, I would love to take it off your hands. Please email me at BVanMidd@chem.fsu.edu.
Brad VanMiddlesworth
