pyrethroids uing TR-5 column??
Posted: Mon Mar 15, 2010 11:44 am
by sanmari
Hi
I want to ID and quantify pyrethroids.
I have a TR-5 column in my TRACE DSQ GC-MS.
Is it possible? Any idea w.r.t temperature program?
SM
Posted: Mon Mar 15, 2010 3:03 pm
by krickos
Hi
This article might help you:
http://yakushi.pharm.or.jp/FULL_TEXT/126_10/pdf/991.pdf
Generally "type" -5 columns seems to work, mentioned in the above article and in others.
Posted: Tue Mar 16, 2010 10:47 pm
by jh1
Pyrethroids run great on our DB and Rtx 5MS columns so you should be good. A number of the Pyrethroids take fairly high temperatures to elute, so you might want to start on the hotter side and ramp up to 300ish.
Posted: Fri Mar 19, 2010 9:14 am
by sanmari
@krickos - looked at the article, thanks!!
@jh1 - will make note of that!!
