buffer preparation confused me
Posted: Fri Mar 12, 2010 7:59 pm
Hi ,
Sorry if i place it in wrong form but i am confused
if i prepared buffer actate (PKa= 4.76 ) ,Volume=1000 (mL) ,ph=7,Concentration=10 (mM)
this is from this web : http://www.liv.ac.uk/buffers/buffercalc.html
my questions are :
1- if i want to control my mobile phase at ph =5.76 , how much do i need to add from the 1000 ml buffer solution above to ( mobile phase 70%methanol water in 500 ml )
2- Does the buffer concentration play important role or it doesn't matter 1 or 10mM ?
3- I have seen in the calculator that they include ( Ionic strength (mM) ) what is this ? because i don't hear about add these number in calculation before
4- is the ph will change with dilution when i dd the some from 1000ml to the mobile phase
i am sure i will find the best help here , so thanks for you all
my questions are :
