LC-MS reproducibility of MS vs DAD signals
Posted: Fri Mar 12, 2010 1:16 am
Having a bit of a nightmare with a drug metabolite standard curve reproducibility for a new assay.
Repeated injections from a single vial give a perfect DAD signals, but the MS signals can vary by 30% !?
Have repeated the exercise with a standard solution of caffeine and experienced the same problem.
Everything (including the quad) in the MS has been removed and cleaned by company technicians - and the problem remains.
Would be vey grateful if a calmer mind can point out an elephant in the room so obvious that I can't see it, or detect a tiny but deadly trick of the evil chromatography elf.
Thanks.
Thanks.
