Inject blank in sequence.
Posted: Fri Mar 05, 2010 1:58 am
Hi all:
Could you suggest the best approach to inject a blank (diluent) when you build a sequence of 2 or 3 standards (low conc, mid conc., and high conc), and sample extracts. The mid-conc. standard is the Continuing calibration verification (CCV), i.e. bracketing standard.
I saw a proposed sequence in a previous thread, with no blank injection.
viewtopic.php?t=7704
I am asking this, because some firms got cited for not injecting blanks between samples, to ensure there is no carry-over.
Also, anyone in pharma doing extra testing for each batch of samples, i.e. testing duplicate sample, spiked sample, control sample, sample blank. This extra testing is popular (required) in Environmental lab, because the results are not predictable. (BTW, we always do 2 injections for each sample, and run the bracketing standard between samples).
Thank you.
Alfred
Thank you.
Alfred
