Force Baseline by Time(with no value) and with value events
Posted: Thu Mar 04, 2010 11:17 am
I am confused with these two events described in waters manual. The description is not clear to me.
It says baseline is drawn from event start to event end. But in the figure it shows the baseline is draw from a point after event start and to a point before event end.
Also I could not digest the concept of baseline averaging. What do you mean by baseline averaging and also how do you set baseline points based on baseline averaging.
Can someone help.
Can someone help.
