Endrin Aldehyde loss in 8081
Posted: Wed Mar 03, 2010 10:18 pm
I have an intermittent problem seeing Endrin Aldehyde in extracts, spikes, LCSs and DCSs by method 8081. No problem with my standards, so it's something in the extraction procedure. Sometimes it's low in water and good in soil, sometimes the reverse. Water extraction by sep funnel, soil by ASE. Sometimes there's a visible drop in baseline in blanks where Endrin Aldehyde should be.
My guess is some contaminant is co-eluting and suppressing the signal, but I can't imagine what it could be. I've checked the common phthalates and they don't co-elute with it. All the other 8081 analytes are fine. Just this one and it comes and goes with no obvious pattern.
Has anyone else seen this, and I hope solved it?
Thanks.
Thanks.
