Baseline Increase
Posted: Tue Mar 02, 2010 12:50 am
Hi all,
I have been having problems in the last couple of days with a jump in my baseline. Last Thursday before lunch my baseline was fairly smooth and consistent. After lunch I have seen this baseline-jump at around 10 to 12 minutes. Here is a chromatograph of a calibration gas mixture before seeing the baseline jumps.
And one with the baseline problem.
Peak 1: Oxygen
Peak 2: Nitrogen
Peak 3: Carbon Monoxide
Peak 4: Methane
Peak 5: Carbon Dioxide
Method Used: Initial 40 C. Hold 3 min. Heat Rate 8 C/min. Final Temp 250
Here is a chromatogram of a sample of Natural Gas with baseline problem:
I did a blank run at a constant oven temperature of 40 C and still saw baseline shift but at a much later time.
Can you guys tell me what is causing this? Thanks for all help.
Peak 1: Oxygen
Peak 2: Nitrogen
Peak 4: Methane
