Calculated mass column packging or maximun mass to inyecte
Posted: Fri Feb 26, 2010 12:33 pm
by Nataliagp
Hello
I would to know, how do you calculate maximun mass to inyected in HPLC column? or how do you calculate mass packaging of a HPLC column?
Thanks in advance!!!
Posted: Fri Feb 26, 2010 1:50 pm
by Uwe Neue
There is no true upper limit of how much mass can be injected onto a column. It primarily depends on how much separation you are willing to sacrifice, as well as a few other things such as details on the running conditions.
Similarly, the "mass of packing" in a column depends on a lot of different things, most importantly the specific pore volume of the packing.
I assume that you want to do some preparative chromatography. If you give more details about what you want to do, better answers can be provided.
