LPG sampling in GC
Posted: Wed Feb 24, 2010 12:03 pm
We are using a HP GC 5890 with FID for sampling LPG. We are using a liquid sampling valve. It was workinf fairly good. But the reproducibility is not OK. We are discussing what is the best method for injecting the sample. We are using a regulator at the entrance of the sample. We are using a normal ball valve regulator but I think that the best would be a double stage regulator? What do you think? WE have a regulation valve at the waste end of the valve.
We are sampling the following way:
1. First valve in sampling position
2. open the sampling valve and regulating the pressure to 50 psi
3. open the waste valve and regulating to get the same 50 psi
4. Wait 30 seconds
5. Inject
We have tried many forms of injection and this was the one that gave us the best results.
Do you know where can I find the best method for sampling LPG?
4. Wait 30 seconds
5. Inject
