using thf
Posted: Sun Dec 26, 2004 3:04 pm
by verez
hi
1. can i use tetra- hydrofuran with ammonium acetate?
2. can i use tetra- hydrofuran with coularray detector?
thank u
Posted: Sun Dec 26, 2004 9:36 pm
by maris
Yes and Yes
Electrochemical Detector Compatibility with THF
Posted: Mon Dec 27, 2004 7:19 pm
by Chris Pohl
Verez,
One note of caution regarding electrochemical detection and THF: there are potential problems with both the "stabilized" version (the stabilizer is BHT which is electroactive) and the unstabilized version can be contaminated with peroxides which are also electroactive. Depending upon your application, you might find it better to use another solvent because of these issues.
