fused peak simulation
Posted: Tue Feb 23, 2010 11:42 am
by sana_sankar
How to simulate fused peaks. What i have used is the gaussian peaks. Gaussian model cannot generate fused peaks, shoulder peaks or the rider peaks.
Posted: Tue Feb 23, 2010 11:56 am
by Don_Hilton
Please clarify - I have generated pictures of fused gausian peaks in Excel many times. So, what sofware are you using to generate this model?
Posted: Tue Feb 23, 2010 3:46 pm
by sana_sankar
I am using C++. I need the mathematical model for generating fused peaks.
How can you generate fused peaks using excel.
Posted: Wed Feb 24, 2010 1:45 am
by Don_Hilton
The equation for the Gaussian curve is given in
http://en.wikipedia.org/wiki/Gaussian_function. A fused peak is the sum of two peaks. Select parameters for each peak (corresponding to height, width, and displacement along the x axis - which would be retention time) and compute the combined signal (f1(x) + f2(x)) at each point x of interest. Where f1 and f2 are the equation for the gaussian, each with the different parameters.
