UPLC Amino Acid Analyser
Posted: Tue Sep 09, 2025 11:05 am
by Giota
Hi everyone,
I’m using a UPLC amino acid analyser with a 17-amino-acid standard, and I’ve recently encountered a problem with my latest runs. In the last few standards, two amino acid peaks are completely missing, while the neighboring peaks appear distorted (“rough-shaped”) and show almost double the expected peak area.
Has anyone experienced something similar? What could be causing this, and how should I troubleshoot it?
Thank you in advance.
Re: UPLC Amino Acid Analyser
Posted: Tue Sep 09, 2025 4:56 pm
by vmu
The more you don't tell us the more we can't help you. There are no fortune tellers on this forum.
Posted: Tue Sep 09, 2025 5:32 pm
by vmu
The "missing peaks" could overlap with the "neighboring peaks". This could double the areas of the "neighboring peaks".
Posted: Wed Sep 10, 2025 5:56 am
by Giota
Thank you for your answer.
Ι am using a reversed-phase HPLC with a gradient elution. From one day to the next, in the same vial (standard), without any changes to the system, Ι observed this change in the chromatogram.
Posted: Fri Sep 12, 2025 9:50 pm
by Jake
Again, as vmu prompted, we can't really help without more details. Many of us here routinely do AA analysis, but I have no idea what method you're using. It being 'reversed phase' doesn't really help much; all the varying methods I've ever used are reversed phase.
Posted: Fri Nov 21, 2025 3:31 pm
by Ruggr2
Did you try lambdalaboratory.com for troubleshooting? They have a free AI troubleshooting platform.
https://www.lambdalaboratory.com/ai-sci ... -assistant
Posted: Fri Nov 28, 2025 6:35 am
by Giota
Apologies in advance for the incomplete information in my original description.
I should mention that I am running a gradient elution on a reversed-phase system. I have already replaced the stationary phase with a new column, but the problem persists. I prepare fresh standards every day, yet I obtain exactly the same issue. My mobile phase is freshly prepared as well.
