Clarus 590 FID
Posted: Wed Aug 27, 2025 8:21 pm
The spring-loaded pin that extends from the collector assembly broke off. Perkin Elmer says I need a whole new assembly but I wonder if anyone else has figured out a way to repair one of these.
Secondarily... I took the thing apart and a little spring popped loose (not the one pushing on the pin I mentioned). I'm not sure where it came from. Any ideas?
