Shimadzu LC10AD VP
Posted: Thu Feb 11, 2010 3:39 pm
We have run into a small problem with our Shimadzu LC 10AD VP pump and i thought i will take a shot at it here for a solution. One of the two roller bearings (a cam follower) doesn't seem to be functioning properly and gets stuck frequently. I am definitely not buying the whole pump because of just a roller bearing and Shimadzu doesn't seem to sell just the bearing (doesn't even have a part number for me to refer to).
Has anybody come across such a problem with the Shimadzu pumps? Does anybody have an idea where to get that specific roller bearing from. It doesnt seem to be a standard bearing and so i have not had success with the bearing suppliers here in Canada. It is about 10mm in length, 5 mm in ID and 10 mm in OD.
Any suggestion/input is welcome. Thanks in advance!
Suresh.
[/i]
Suresh.
[/i]
