Simple Standard for DB-5 MS column performance check
Hello!
Anyone could recommend me a simple standard/ mixture to check the performance of a DB-5MS column (using MS detector)?
I am thinking of a mixture of analytes/ solvents, nothing too expensive or that requires certification.
Thanks in advance :)
Whip up something like this.
https://www.agilent.com/store/en_US/Pro ... 0/200-0310
Whenever I've purchased a new GCMS system from Agilent, they install a 5-phase column and use this test mix to ensure it's good.
Consider using the Grob Test Mix - I’ve used it to monitor performance and it has a lot of historical data on what it should look like. It will also almost certainly stay available in the future.
Available from Merck, Restek and the other usual suspects.
https://www.sigmaaldrich.com/US/en/product/sial/86501
