Error reading from DC @ USB
Posted: Tue Jun 10, 2025 4:42 pm
I have a new ICS-6000 installed 2 weeks ago, then after install had to switch computers. Old computer wouldn't run Chromeleon 7.3.2. Switched computers, everything setup properly. But the past few days, I have been randomly receiving an error on my cation system. Error receiving data: Error reading from DC-6000 @ USB. A device attached to the system is not functioning. It then stops the squeance but doesn't shut down the DP, EG, or even lose connection with the DC. It's also not consistent, happened after 3 days of running, or 12 hours or even after a sample or two. I have connected all data cables directly into the computer's USB ports and made sure not to use the fast ports as well. Power for all modules are plugged into a UPS power bar. Any suggestions welcome.
