Leaving a ferrule in place
Posted: Sat Jun 07, 2025 8:07 am
Please forgive what may seem a very stupid question...
In the coming week, I will need to change out a column from an Agilent GC-MS for a different type and then after a week or so put the original column back on.
Because the ferrules are obviously pretty much welded to the column (and I would have to make fresh cuts either end), this would mean snipping about 1ft of column at the transfer line end (and a few inches at the inlet end) so that I can reinstall. The loss of column length from the transfer line end is something that I would prefer to avoid.
It strikes me that taking off the requisite few inches at what was the inlet end and then plumbing that into the transfer line end and plumbing what was the transfer line end into the inlet would minimise loss of column length, but I would be left with a ferrule about 1ft from the inlet on the column.
Would this approach be acceptable and are there any consequences for having a 'free' ferrule attached to the column?
Kind Regards
R
Kind Regards
R
