Low level alcohol/spirit analysis GC-FID
Posted: Wed May 14, 2025 12:07 pm
My configuration;
Agilent 6890N GC FID
Column1: CP WAX 57 CB, 50m 0,25mm 0,20um
Column2: DB 624 UI 60m, 0,32mm, 1,80um
Method: Commission Regulation (EC) No 2870/2000
According to REGULATION (EU) 2019/787;
Article 5
Definition of and requirements for ethyl alcohol of agricultural origin
(d) its maximum levels of residues do not exceed the following:
(i) ethyl acetate: 1,3 grams per hectolitre of 100 % vol. alcohol;
(ii) acetaldehyde (sum of ethanal and 1,1-diethoxyethane): 0,5 grams per hectolitre of 100 % vol. alcohol;
(iii) higher alcohols (sum of: propan-1-ol, butan-1-ol, butan-2-ol, 2- methylpropan-1-ol, 2-methylbutan- 1-ol and 3-methylbutan-1-ol): 0,5 grams per hectolitre of 100 % vol. alcohol;
We want higher alcohols to be at or below the LOQ of 0.3 grams per hectolitre of 100 % vol. alcohol - The LOQ of each of the 6 alcohols that make up the higher alcohols is approximately 0.05 grams per hectolitre of 100 % vol. alcohol.
Is it possible to get down to these levels?
My configuration;
Article 5
