5973 MSD Tune Abundances Off HELP
Posted: Fri Feb 28, 2025 1:06 am
I cleaned the 5973 source and now the 219 abundance is ~30% higher then 69, and 502 is much higher than usual (~80,000 vs ~14,000).
I tried resetting the autotune file thinking it could be corrupted, no luck.
I tried cleaning the source again, no luck.
Any ideas? The background sensitivity has increased significantly and I have a feeling this is the cause. There are no leaks in the system.
