Comparison of Z-HILIC Columns
Posted: Tue Feb 18, 2025 11:09 pm
1. InfinityLab Poroshell 120 HILIC-Z, 2.1 x 150 mm, 2.7 µm
2. Atlantis Premier BEH Z-HILIC VanGuard FIT Column, 2.5 µm, 2.1 mm x 150 mm
Does anyone have experience using either of these columns for general metabolomics applications? I am having trouble deciding which one to get. One seems to offer higher chemical stability at extreme pH values while the other can tolerate significant more backpressure. If anyone has used both, your input would be greatly appreciated!
Thanks in advance!
Thanks in advance!
