Extraction pesticides feathers QuEChERS
Posted: Sat Feb 08, 2025 6:18 pm
Hello
My main goal is to determine the presence (and possibly the concentration) of a series of compounds such as organochlorine pesticides, HCH, and PCB in bird feathers. I want to perform the analysis using HPLC. However, I currently have an issue with choosing the extraction method. I have a large amount of acetonitrile available, so I thought that the best choice, based on the materials I have, would be to use the QuEChERS extraction method. I would like to know if this method is suitable for determining these compounds in a complex matrix like a feather. If so, is there a cheaper alternative for the dSPE step? I am referring to sorbents such as PSA and C18. Is silica gel a suitable alternative?
Thank you very much!
