Purge and Trap connection to PTV injector
Posted: Wed Jan 15, 2025 6:57 pm
I need to connect a CDS 8500 purge and trap to my 8890 GC for isotope analysis of VOCs in water samples. The GC is equipped with a both a s/sless injector (back inlet) and a PTV (front inlet). From previous experience on this type of analyses, I know I will need cryofocusing and I was hoping to be able to use the PTV for this purpose (-100C, I have a LN2 dewar connected to the PTV).
Would that make sense to have the deactivated capillary from the heated transfer line going through the PTV and connect it directly to the GC column in the oven (or something of this order)? Is there any extra parts I need to do that, or tricks I should know?
I know the traditional way of doing it is to connect the P&T to side of the s/sless injector. In this case I will need to buy a cryotrap, which I would like to avoid.
If this is relevant, I do compound-specific isotope analysis, so I need a relatively high mass of compound; hence the P&T, and we use 0.32 mm columns.
Violaine
Violaine
