high initial temperature
Posted: Wed Jan 08, 2025 9:40 am
Hi All,
we are using a CP-Volamine column for a separation of semi-volatile analytes (BP ~ 400°C). Their elution temperature is ~280°C in gradient elution. The isothermal limit of the column is 265°C and the gradient limit 300°C.
Right now we start the gradient at 150°C and ramp to 280°C.
Do you see a problem with having the inital temperature yet higher, e.g. 225°C for the gradient elution?
The ramp rate could then be somewhat reduced to effect elution of the components ON the gradient slope rather then directly behind it.
I only ever see 40/50°C initial temps or up to 150°C for semi-volatiles applications.
Thank you!
Thank you!
