GC-FID (Response factor for hydromorphone)
Posted: Mon Dec 30, 2024 1:20 pm
by Marko Bokhanovskyi
My current task is to quantitatively determine hydromorphone using GC-FID. Unfortunately, authentic hydromorphone standard is unavailable. However, I do have a morphine reference standard.
Could you confirm if the effective carbon number (ECN) concept is applicable in this context? If so, I would appreciate assistance in calculating the predicted response factor for hydromorphone concentration relative to the peak area of morphine.
Re: GC-FID (Response factor for hydromorphone)
Posted: Mon Dec 30, 2024 2:04 pm
by Peter Apps
The molecular formulas of the two are the same, and so the FID response per unit mass or mole will be very similar if not identical.
Posted: Tue Dec 31, 2024 2:32 am
by AICMM
This is the perfect example of an application that would be solved by the use of a PolyArc reactor.
Best regards,
AICMM
