Standard prep using liquids
Posted: Thu Dec 26, 2024 9:08 pm
Hello; new member here. I have been tasked with making standards from liquid stocks obtained from a supplier.
I am also not the best at stoichiometry.
I need to prepare a 10,000 ppm solution of 3-Pentanol. The final volume needs to be 500 mL. Here is what I came up with:
1. Calculate the mass of the solute needed: Mass of solute (mg) = (Desired ppm concentration) x (Volume of solution in mL) / 1,000,000.
(10,000 mg/L)(500 mL)/1,000,000 = 5.0 mg
Volume needed = mass of solute/(purity as decimal) (density in g/mL)
The 3-Pentanol I have is 98% pure, density = 0.815g/mL.
5.0mg/0.7987 = 6.26mL needed in 500mL.
I was taught that density must be included in the calculations when making solutions from liquid solutions. The method I was given uses weight only for making this solution from a liquid.
Thank you in advance!
