Agilent GC-FPD (6890 N) signal and baseline problems.
Posted: Tue Dec 17, 2024 1:43 pm
Hi all,
I'm new to the GC world. I have a Agilent GC-FPD (6890 N) with 60/80 Chromosil 310 column, Air and Hydrogen gas as fuel, Nitrogen gas as makeup gas and Helium gas as carrier.
I'm facing some problems and hope to get suggestion and opinions from this forum.
1. The signal output is dramatically different. Previous the signal output was around 7.0. The next day I switched on the GC, the signal output was around 890.0.
2. After I changed Hydrogen gas (as it finished), the baseline was behaved unexpected. The baseline was stable and the 20ppm SO2 peak as per attached
. After few runs, I got a chromatogram as per attached
and the baseline started unstable.
3. Hence, I decided to change another cylinder of hydrogen gas. The signal output was increased to around 1166. It looks stable but my 20ppm SO2 peak was not appear.
May I know what cause these problems and how should I solve it ? Any suggestion is highly appreciated.
Thank you very much.
and the baseline started unstable. 3. Hence, I decided to change another cylinder of hydrogen gas. The signal output was increased to around 1166. It looks stable but my 20ppm SO2 peak was not appear.
