Nitrosamine analysis nightmare
Posted: Thu Dec 05, 2024 12:21 pm
Dear all,
We are facing an analytical nightmare with N-nitroso diclofenac analysis by UHPLC/MS (SIR). We can not get a valid method due to issues with recovery/stability issues.
Due to nitrosamines unstability, we set the injector temperature to 8 ºC, but even with standards in water, the signal decay over time was significant. We also tried adding ascorbic acid (1%) to avoid oxidation, getting no improvement. Surprisingly, the following day we always recover (or even exceed) the signal intensity by injecting the same samples stored in the injector. This blowed our mind, it could not be an estability issue, wright?
We did the same test at 18 ºC and we also find a higher signal and a slight to moderate signal reduction with time, but at that time, if we set the injector temperature to 8ºC again, then we see a significant reduction in the peak area and height. ¿A solubility issue? At concentrations around 1-10 ng/mL this is unlikely...
We tried different aspiration speeds with no chanhe in signal.
We are lost... any idea?? HELP!!
