triethylamine peak not eluted
Posted: Tue Nov 05, 2024 4:51 am
kindly give suggestion to resolve issue regarding trimethylamine peak not eluted in sensitivity solution using DMSO as diluent and added 0.8gm of Potassium hydrogen phosphate other solvents are MDC, Toluene and benzene
column :Rtx-5 Amine (Crossbond® 5% diphenyl-95% dimethyl polysiloxane) (Make: Restek) 30m x 0.53mmx3.0μm using
Headspace methodology,the conc. of TEA was 0.3 ppm w.r.t. test solution
