Create a report to display minimum and maximum values
Posted: Mon Oct 21, 2024 8:20 am
I'm asking for help with Empower and its reports method.
I need to make a report where I will be able to display some result lines among several vials and injections.
An example is better than a long explanation:
Here's a table with several rows and I want to display :
https://imgur.com/a/9JnpzcY
1. First, a report displaying all rows (I know how to do this)
2. A summary table where I display only the vials with the minimum and maximum area.
In this case, I need to display vials 3 and 4 (the two injections of each vial is necessary not only the min and max) in order to calculate the RSD of the 4 injections.
I've tried custom fields, but unfortunately without any convincing results ...
I hope I've made myself clear.
Thanks a lot!
Thanks a lot!
