I re-installed LCsolution version 1.23 on a different PC to replace the old and non-working PC. However, while I was trying to establish the connection between PC and LC hardware by performing configuration under the software, it didn't work and always appeared with a "[0100] unexpected error" message. FYI, the LAN connections were used to connect PDA and CBM-20A with PC via a router. The IP was established where I can see PDA and CBM-20A via web browser when their assigned IP were typed on the web browser. Re-installation of the software didn't help to fix it. What else can I check to make LCsolution connect with my PDA and CBM here? Seeking for advice here to move on. Thank you.
