I was asked to put together a 5890 GC from three damaged ones. I go it up and running manually. I had to buy a used 7673 auto injector from 3rd party vendor and it runs first run in the sequence but it does not advance to 2nd or 3rd samples in the same sequence. We have a similar towers and I matched all the settings exactly with the other ones, still it does not run the 2nd vial or further but stops right after the after run finishes and goes back to ready state. am I missing something here ?
