USP Tryethyl Citrate - Assay / Related chromatography issue
Posted: Wed Sep 25, 2024 12:55 pm
Dear all,
I hope this message finds you well.
I would appreciate your support in resolving an issue I encountered during the verification of the USP Assay/Related Substances test for Triethyl Citrate.
Specifically, I am experiencing failures in the SST (System Suitability Test) — including standard check and %RSD — for the two components. The peak for Triethyl Citrate shows baseline interference, which is contributing to the SST failure.
A significant challenge is that, following the USP method, the standard concentration of 0.02 mg/mL in Empower produces an area response of 6-7, which is quite small and likely to cause SST failure due to insufficient peak area. Unfortunately, I cannot modify any parameters of the method.
I would like to ask if anyone has experience with testing this excipient and could suggest any improvements or adjustments I might consider to address this issue.
Thank you in advance for your assistance.
Best regards,
Simone
Best regards,
Simone
