Requesting Guidance on Chromatography Technique Optimisation
Posted: Fri Sep 13, 2024 6:24 am
Hello Everyone,
I'm requesting advice from the community to help me get better at chromatography. Although I've been using chromatography for some time, I'm running into certain difficulties that I'm hoping you can me with.
In particular, I'm having trouble maximising column efficiency and fixing peak shape problems in my chromatograms. I've attempted a number of strategies, such as modifying the flow rate and experimenting with various mobile phases, but I haven't been successful in getting the desired outcomes.
I would also appreciate any advice on the most recent developments in chromatography technology or best practices that could improve my existing setup. I would be very grateful for any insights you might have if you have used sophisticated methods or tools that have improved your work.
Thank you in advance.
